Help!!
hey guys 98 TA threw a code the other day...hooked it up to HP tuners and this is what i got.
[PCM] P0121 - TP Sensor Circuit Insufficient Activity (Old) (Immature)
[PCM] P0122 - Throttle Position (TP) Sensor Circuit Low Voltage (SES) (History) (Immature)
[PCM] P0153 - HO2S Slow Response Bank 2 Sensor 1 (Old) (Immature)
[PCM] P0155 - HO2S Heater Performance Bank 2 Sensor 1 (Old) (Immature)
[PCM] P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage (History) (Immature)
Thanks guys. Let me know what i should ddoo!!!
The throttle position codes look out of place.
I'm going to guess that the O2 codes are from your LT headers - not uncommon. These will require tuning to go away.
Check the connections to your TP sensor. If everything looks okay, then you may want to replace the TP sensor.
the sensors are pretty much brand new...i replaced em when i put the new FAST TB on...i think it was the connection. I checked it and messed with it a little and the next time i cranked her up the SES light was off. Its come on like once since then and goes off with a couple of cranks....ssssssooooooo idk! but thanks!
ANYONE ELSE?
ANYONE ELSE?
