IAT effect on afr
With a carb, colder temps mean leaner and vice versa.... well with LSx pcms at least, when the computer sees colder temps, it pulls fuel. So with a lower IAT reading, it will pull fuel making your car go leaner.
The reason it pulls fuel is because of the way the MAF works. Basically, it is referenced from the IAT temps and based on what temp the IAT reports, it can calculate how much air is flowing over the MAF wires (which are heated to to a consistent temp). Colder air cools things off better than hot air does, so the ecm interprets the colder reading of the IAT and tries to compensate by reducing the amount of fuel delivered, because if the air were in fact colder (but the same volume) the MAF would be reading higher than it is.... Colder IAT means colder air, MAF sees the same air but the computer uses the IAT readings to bias the MAF readings and thus the ecm thinks it is seeing less air, when in reality it is seeing the same amount just at a different percieved temp (still obviously the same actual temp). If any of that makes sense... lol
The only way to help alleviate this problem is to change the "Cylinder Charge Temp" bias settings, and skew them more towards ECT and less toward IAT. What I did was set the bias to 1.0 across the board, making an even split of IAT and ECT bias. This works best if the IAT is in a good location to see moving air, and not in a dead spot in the air box for example. You will likely have to re tune your VE though.
However, in SD mode, it still maintains this odd behavior despite the lack of a MAF sensor. I think it is probably due to the fact that these cars were never designed to run in SD mode, and therefore this behavior is kind of hard wired into them and can't be fixed unless you use some custom OS or something of that nature.
Warm I go leaner, cold I go richer (via Trims/wideband). What you also might be experiencing is as you have added additional airflow and your IAT is closer to ambient (colder), the engine is wanting more fuel to burn the charge. That is why many people re-calibrate their MAF Table after any change in front of the MAF.
Think about it. It is leaner, because it wants more fuel. Colder air is more dense than warm air. If it is lean, it wants more fuel. Even changing to an Lid or K&N filter usually make you tend toward lean. You have enhanced the engines ability to ingest air, but have not re-tuned it to re-calibrate the additional fuel required.
Though some have had success altering ECT/IAT bias tables, personally I would want my engine to take advantage of colder IATs. That was your point in adding a cold air intake system.
Depending on whether your SD, MAF, closed or open loop will determine which way you need to go on this.
Perhaps some others will chime in, but that has been my expierience.
Good luck.
..WeathermanShawn..
If the MAF is active, it doesn't care what the temp is. It's already temperature compensated by design. The error you're seeing is because you changed the way air enters the MAF element through the new filter and tube arrangement. You NEED to recalibrate the MAF airflow vs frequency table (in steady state!) to establish the new curve that matches your hardware. This should be done in open loop using a good quality wideband before making any other changes.
For SD, you just need to leave the IAT-ECT temp compensation and sensor location near stock while correcting the VE table (in steady state!) with a wideband in open loop.
If you get these two main changes right, lots of other little quirks like the temperature influence you're seeing will fall into place. Don't make this harder than it needs to be...
Colder IAT = richer
Higher IAT = leaner
You should only experience this in OL with a non-perfect bias table. In closed loop with MAF, UNLESS YOUR TUNE IS WRONG AND YOUR FUEL TRIMS ARE POSITIVE, your measured air fuel should not change.
what if you have to move your IAT, like a super/turbo charger?
if you're correcting VE and the bias at the same time, how do you know how much is each factor contributing?
Notice how the OP mentions that the ECM is seeing a colder temp, when in reality the temp has not changed just the temp the IAT sees has changed (the air going into the motor is the same air). Why would the ECM be fine at seeing 100* IATs with 50* air, and when the IAT sees 50* temp at 50* air, it goes leaner? It should only be adding fuel, since colder air = more O2 = need more fuel. Trust me, these computers work backwards compared to a carb, and it takes getting used to.
Further... VE aside, how do you solve for bias anyway, particularly in a relocated position as mentioned? How on earth do you describe and control heat soak?
Sounds like if your MAF enabled, you need to recalibrate your cylinder airmass vs MAF frequency to get the proper fueling and spark load.
RoDan, I am not sure I am totally following you.
g/cyl = VE*MAP/charge temperature.
The PCM calculates the charge temperature (in degrees Kelvin) using the following formula
273.15+IAT+((ECT-IAT)*factor) where factor is obtained from this calibration.
At low airflow "factor" is closer to 1 which weights the charge temperature in favour of ECT.
At high airflow (>150g/s) "factor" is closer to 0 which weights the charge temperature in favour of IAT.
The theory being that heat (ECT) is transferred from the heads and manifold after the IAT has been measured and prior to the air entering the cylinder.
If factor is 0, then the charge temperature will be IAT, if factor is 1, then the charge temperature will be ECT, other values for factor will blend the charge temperature between IAT and ECT accordingly.
Few times I have done open-loop SD tuning, higher charge temperatures have always resulted in less airmass. Idle for 1-2 minutes on a hot day (open-loop) and watch your AFR go leaner and leaner as ECT and a heat-soaked IAT sensor increases.
We are probably getting off the OP's question, but it sounds like you have a different approach.
Andy, hope it works out for you. Best of luck.
..WeathermanShawn..
You are correct about the bias though, my mistake
..WeathermanShawn..
..WeathermanShawn..
In his first post he says:
"well with LSx pcms at least, when the computer sees colder temps, it pulls fuel. So with a lower IAT reading, it will pull fuel making your car go leaner."
Then he completely contradicts himself by AGREEING with this statement:
"But temp does have an effect since the car runs leaner during the day here in AZ, and a lil richer at night when it gets cooler"
Maybe he's had too much
I probably did have too much
