How do you read two dif year (LS1 EDit)
Old Oct 30, 2003 | 06:32 PM
HumpinSS's Avatar
Default How do you read two dif year (LS1 EDit)
LS1 edit files. I want to copy one table to the other and when i try and read the 02 file it tells me the vin isnt registered and if i try to read just one particular table it tells me the segment ids dont match.
Old Oct 30, 2003 | 07:13 PM
MNC5's Avatar
Use select all and copy on the table you want to copy. Then go to the other table, select all then paste.
Old Oct 30, 2003 | 07:33 PM
HumpinSS's Avatar
Is that asuming they are the same year? What about different years I cant even open the file to look at the tables on the 02file
Old Oct 31, 2003 | 12:27 AM
Mike00FRC's Avatar
Sorry, but I don't think its possible. You could try having someone with the same year open it and copy/paste to an excel file then send it to you for you to copy/paste in to edit. Not sure if its possible, but if it works, it beats plugging everything one block at a time.
