LT1 Edit
Old Oct 30, 2003 | 06:40 PM
Corsa GT's Avatar
Default LT1 Edit
Just considering buying it. I've got an OBD-I 94 Trans am with an M6. How useful would it be to me?
Old Oct 30, 2003 | 07:36 PM
Camaroholic's Avatar
Depends on what you've got done. If you've got a basically stock car, you can do fans, maybe disable a couple codes, but that'd be about all I'd recommend.
If you've got mods, then the sky's the limit. It really starts to shine when start modding.
Lots of info in the archives at http://www.lt1edit.com
HTH,
Andrew
Old Oct 30, 2003 | 08:06 PM
ChrisB's Avatar
get it (or tunercats)
http://www.carputing.com
http://www.tunercat.com
both work - first thing you need to do is get a cable from andrew for either
http://www.akmcables.com
I would get them even on a stock car to fix things like the fan turn on, skip shift, etc. Especially for the price of tunercat (what, 100 bucks for all of it) you can't go wrong.
Go ahead and get a copy of TTS DataMaster (I think andrew can sell keys for that also) also.
Old Nov 3, 2003 | 07:41 PM
Corsa GT's Avatar
are there any individuals out there or manuals or something that can teach me how to edit things with LT1 Edit, and what to edit? Becuase i've done a decent amount of research and found the lists of things each can modify. I really like Tunercats. I downloaded a shareware version and i like it, especially for the price! I plan on getting headers over the winter, too. I've read from a lot of people that tuning needs to be done so the O2 sensors don't sh*t a brick and run your engine super lean or super rich. Would this be something that with a little reading I'd be able to do?
Old Nov 5, 2003 | 12:24 AM
fastsspr's Avatar
YES somebody have a manual or similar to learn how to use an LT1 or LS1 edit?
