Intermiten codes
Old May 1, 2009 | 11:06 AM
chase3's Avatar
Question Intermiten codes
Every once in a while i will throw the tps code ( just installed a new tps just to make sure). I took it to my tuner and he says its like an intermitten code. He was holding on high rpms and said he also saw a little bit of it on the map sensor. So not sure what to do. It will throw a code and then the next day the SES light will just go off.. ANY IDEAS?? THANKS Chase
Old May 4, 2009 | 02:41 PM
NoGo's Avatar
Sometimes the bump stops on the TB are out and it will cause the TPS to go out of range. Have your tuner take the throttle all the way open, and all the way closed and make sure that the voltages are in range.
