only real tuners please
I tried to smooth that out as well as some raf changes with the help of other members. Schantin thanks for the help man but if i could see what a real ms4 tune looked like or a close tune i think i would understand the numbers better.
edcmat-l1 hey thanks for rip man how many years experience in tuning? Well i just started 3 weeks ago i went from a car that would not run at all to a car that runs and starts. It my not be perfection, like a pro tuner like your self, if my tune was I would not be here ok mr perfect thanks for the help.
It's working out great here. Thanks for asking.
BTW, it doesn't have much to do with experience. It's about reading and following directions. Almost all the info you need is right there in the help files.
As far as the help files go you are right they are right there but no where does it say anything in around about way where i should be as far how close these numbers should be. Atleast from the serches i have made it all comes down to 1 problem.
1. I make a change close to where something should be and the car wont fire.
The car runs good on this file witch dont make sens and then i do something that should make it better and it wants to not idle or fire up or if i do get it to fire it serges so bad it dies.
Sorry if i came off as a **** stick.
If your changes are hurting the car, then you are either:
1. working with bad data/logs
2. adjusting the wrong areas
You need to make sure you have failed the MAF if you are trying to make changes to the VE. If you haven't, your changes either won't work or be counter productive.
I would suggest running a couple data logs and posting them here. That way we can better help.
You'll need to include certain pids. TPS, MAP, STFTs (long terms should be turned off)dyn cyl air, dynamic airflow, timing, KR, temp, IAT, speed, that's all I can think of off the top of my head.
Read the scanner help files and figure out how to set up a VE histogram.
I called up my tuner today looks like it will be awhile till i can get in but i need to rent a trailer or see if a buddy will lend me his till then im looking at 3 weeks to a month to play with it before it gets on the dyno and some street tuning.
So im down to keep playing with it when i get back in town i will start fresh from what i have done so far and work from there.
Best Regards.
i am just trying to get it close enough to drive to chicago in a few weeks to get it tuned right unless you got some bright idea's ?
the tune i have now i plan to pull more timing and ad more injector
If you want to do it this way, there is an instruction how to that works. Look up Cpig's HPT tuning guide, I got it off of the HP tuners forum. Listen to Ed, he knows what he's talking about.
Your MAF isn't failed in the tune which is shown how to do so in the instruction guides, but you go to Engine Diagnostics>Airflow>MAF Fail High and set that to 0. If it was failed, in your log the MAF would be 0. I don't have the license or I could try and help.
Tuning the MAF or VE is basically the same process. You need to learn how to use your histograms. The only difference between the two (maf or SD) is which histogram to use. You can use your STFTs to dial in the part throttle of both. You don't need a wideband.
then would jump back in the blue up to 6000 rpm while testing today so what i did was smoothed out the mountain range of a ve table took away some timing and added fuel in the power enrichment.
the idle serge is gone for the most part one time today it did die on me after i started it up and had to restart it im waiting yet to see if i get any codes i may.
