Tune Required
Old May 6, 2009 | 07:03 PM
laughatrice's Avatar
Default Tune Required
I know this is a widely subjective question but if I can get some opinions it will help me greatly. I am currently in the process of converting a N/A solid roller 418 motor to FI.
A little background the previous heads were GTP Stage III LS6 heads and 248/647 114 Solid Roller Cam making approx 11.2:1 compression on 93. The motor made 505rwhp/471rwtq. I am swapping for Patriot Stage III LQ9 heads and the following FI comp cam.
Cam specs are:
Dur @ .050 232 int 240 exh
Lift .595 int .608 exh
I plan on running at least 14# of boost max of 16# once the procharger is on. Now I know a tune is required once I get the blower installed but for just the cam and heads how bad off will I be. Is it a must or can I get by just to start the motor and light driving this is not a daily driver. I don't want to do any damage. I am planning on 9.5:1 to 10:1 compression after the new heads and cam. I also recognize the substantial power loss I will probably get swapping all of this stuff but I'm setting myself up for some decent boost.
Thanks
