No communication with ODBII Port
Old May 7, 2009 | 12:18 AM
1fstGM's Avatar
Restricted User
Default No communication with ODBII Port
I have a 2000 Trans Am Ws6 I am trying to read the codes on and can't seem to communicate with the PCM? I checked all fuses and they were all good. Noticed I didn't have any power going to the port. I think this is most likely the problem. Anyone know why there might not be power going to the OBDII port? Anyone with similar problem? THX!
Old May 7, 2009 | 07:43 AM
slow's Avatar
does your cigarette lighter work? they share a fuse and it is likely blown.
Ryan
Old May 7, 2009 | 11:23 PM
1fstGM's Avatar
Restricted User
I will check on this right now.
Old May 7, 2009 | 11:26 PM
1fstGM's Avatar
Restricted User
Cigarette lighter doesn't work! Is this fuse labeled cigarette lighter? Is it located inside the car or in the engine compartment?
Old Jun 14, 2009 | 09:30 AM
MUSTANGBRKR02's Avatar
You ever figure this out? Mine is doing the same thing but the cig acc fuse is good
Old Jun 14, 2009 | 10:35 AM
I guess it helps if you pin out the right one for power mine is good , looks like it is going to be the dongle.
