alternator problem
Old May 11, 2009 | 09:51 AM
mmorellicamaross's Avatar
Default alternator problem
My alternator is not recharging and this is the 3rd alternator tried. first alternator was damaged by power steering fluid leak and the alternator and red wire alternator wire were covered in powersteering fluid, could this have shorted the connection out and is there a way of testing this wire to the pcm the see if it is the wire?
Old May 11, 2009 | 10:04 AM
blueshark123's Avatar
Have you had the alternator tested?
Old May 11, 2009 | 11:54 AM
I had it tested while still in the car and they told me the alternator was ok. should I remove it and have it tested. This is the 3rd one I have tried. On there tester it said there was a bad wire. I checked the black wire with a test light and that had power so the only other wire is the red wire on top. When I put the 3rd alternator in it was ok for about a minuate and then went bad on the gauge, the 2nd alternator did the same thing.
Old May 12, 2009 | 01:20 PM
another bad alternator, I am done buying prefab alternators,this is the 3rd bad one, went with a brand new dealer alternator, will see what happens.
Old May 14, 2009 | 12:24 PM
car runs great.......
