bouncing off A4 limiter 02 camaro ss
Old May 11, 2009 | 03:55 PM
dondb's Avatar
Default bouncing off A4 limiter 02 camaro ss
I have a diablo predator and one option is to raise the rev limiter at wot....would you raise this a few hundred rpm or lower the rpm and mph on the shift points. It is a stock motor with a few mods (in sig) 3000 stall, and wondering what the valve springs could handle, which would determine how i go about getting rid of limiter being activated.
Old May 11, 2009 | 04:14 PM
twitchtwice's Avatar
the stock cam stops making power after 5900 i believe so there is no point to go above that
Old May 11, 2009 | 04:30 PM
dondb's Avatar
Got it.....thanks! So looks like i'll just lower the rpm and mph shift points.
Old May 11, 2009 | 04:41 PM
troopercar's Avatar
and maybe speed up the shift itself.
if you can do that with the predator
Old May 12, 2009 | 06:50 AM
dondb's Avatar
I have a built tranny from performabuilt....i think that is done on the build along with line pressure increase, i'll call them. The Predator does have the increase shift speed, so after i talk with Frank at PB...it may be an option?
