No tach signal reading
Old May 13, 2009 | 01:04 AM
proelky's Avatar
Default No tach signal reading
It's late, did a search and came up with NOTHING. I remember reading someone had an issue with their tach, and engine running; but the scanner wouldn't pick up a signal via handheld. I'm having that issue on a recently purchased car....ANYONE? This is not the only problem we're having, just trying to start somewhere.
Old May 24, 2009 | 08:10 PM
Justin Gibbons's Avatar
i had the problem a couple years back and I thnk it had something to do with the crank position sensor. I think
Old May 25, 2009 | 12:33 AM
blackLS1m6's Avatar
Is this for the factory tach? If so i would check the ground on the back of the drivers side head, the tach signal comes from the cam sensor.
Old May 27, 2009 | 10:41 AM
MY99TAWS6's Avatar
My cam sensor went out .Got codes for that. Tach also went out. Any cam sensor codes? Cam sensor gives the info to tach.
