Reasons for false knock?
Old Nov 10, 2003 | 06:48 AM
HumpinSS's Avatar
Originally Posted by WS6 GreeN
OK guys, help me out. After LT and Y install, I get KR at 4800-5100 RPMs at WOT. Nothing is hitting on anything that I can tell... Right at 4800 I get 3.9 and it gradually goes down but not before it robs me of power. Any suggestions? I've switched to stock MAF, took off the MAFT and neither helped the problem. I can't hear any knock.
Get some high octane gas and see if it goes away.
Old Nov 10, 2003 | 11:11 AM
MYBLKSS's Avatar
well i put a catch can setup on the car this weekend we'll see if that helps. I don't have enough time to do the pulley right now. Can I remove the asp pulley without removing the whole fan assembly? Is there anyway to tell if it is the pulley without actually removing it.
Old Nov 10, 2003 | 11:29 AM
HumpinSS's Avatar
Have you tried the high octan gas. I am pretty sure one of the Sunoccos in Jersey has some 100 or 104
Old Nov 10, 2003 | 12:02 PM
MYBLKSS's Avatar
Yeah I already tried didn't help any.
Old Nov 10, 2003 | 05:05 PM
WS6 GreeN's Avatar
I'll try some high octane gas and see what happens. Could carbon buildup on the pistons cause knock? I use Chevron gas and I know that Techron, an additive in Chevron gas has been known to cause pinging. I am switching brands.
Old Nov 10, 2003 | 06:27 PM
WS6FirebirdTA00's Avatar
question, would being in 6th gear and giving it a lot of throttle at 50 mph cause the engine to knock 1*? just a question, thought i read if u put the engine under heavy load liikethat and cause it to bog it would cause some KR, is this true?
Old Nov 10, 2003 | 10:06 PM
skippytheloon's Avatar
yea, thats true, it does cause Kr. Bad habit
*question*
How are yall looking for kr while driving at wot??
isn't that kinda dangerous, I can't imagine looking at my diablo when my car is fishtailing
Old Nov 11, 2003 | 06:31 AM
either quick glances ort i prefer having my friend come, its a lot easier and safer this way lol
Old Nov 11, 2003 | 07:49 AM
HumpinSS's Avatar
EfiLive has pid that record max values. This is what i glance at after making a WOT blast.
Old Nov 11, 2003 | 12:52 PM
MYBLKSS's Avatar
I just create a log file in auto-tap and then load it into excel
Old Nov 11, 2003 | 02:30 PM
ssfiress's Avatar
try getting a new computer. mine got fried last weekend adn we threw a new one in. got it flashed with the latest updates with revisions of false KR and took it out and tuned with ls1 edit. ive got no knock retard anywhere through out every gear, cruising to WOT. i pulled a ton of timing to combat the KR before so it slowed me down but now i feel that my car pulls like a ****. just my experience.
Old Nov 11, 2003 | 05:56 PM
  #32
WS6 GreeN's Avatar
You saying there is an upgraded program for our PCM's? That would be something to check into. I've noticed if I go up a hill in 6th, it will cause KR so I now shift into 5th. Granted, I believe its false, but just in case...
Old Nov 11, 2003 | 06:23 PM
  #33
yeah same here, anything in 6th gear under 90 puts a lot of load on the engine
Old Nov 12, 2003 | 08:00 PM
  #34
ssfiress's Avatar
yeah with my old pcm my car would show KR in gears 4,5 and 6. in 4th around 45 mph and moderate throttle position, 5th around 60 and up same throttle position, and 6th around 80 same throttle position. at first i had the new computer put in and we couldnt hook up to it through the port under the dash so we had to take it to fuel injection specialties and they had a portable computer scaning device (like the one you see at the dealerships) she uploaded a new stock 00 SS file with the revisions for false KR and then went out to my car and flashed my new computer with the file. you have to make sure the # 1 segment id's match though before you can load any thing in your pcm. we started from scratch tuning and no KR anywhere and the car feels better than ever. im stoked the dude fried my pcm.
Old Nov 12, 2003 | 08:01 PM
  #35
ssfiress's Avatar
also when i shifted gears for a split second there was KR about 3 degrees at wot.
Old Nov 12, 2003 | 08:03 PM
  #36
ssfiress's Avatar
didnt have to pay for the puter, flashing, tuning or anything, also got unlimited use of the dyno! ssssssick
Old Nov 12, 2003 | 08:21 PM
  #37
damn u lol
Old Nov 12, 2003 | 09:00 PM
  #38
purevilss's Avatar
Thanks for all the advice wrote up. I ended up finding my KR issue and just wanted to share. On my A4, there is a clip on the bottom drivers sde that holds two trans lines in place. the lines were out of the clip and although there is not much movement in them, they were causing me lots of KR. Now they are back in the clip, no KR. I would have never guessed!
Old Nov 12, 2003 | 09:03 PM
  #39
hahahahahahahahaha damn! well at least it was a FREE and easy fix! glad to hear u found it
Old Nov 13, 2003 | 07:25 AM
  #40
MYBLKSS's Avatar
Are you kidding me those F..ing knock sensors are that sensitive..I don't think I am ever going to find it but you know i will be checking the Tranny lines next.
