11.5 AFR at Idle
Old May 14, 2009 | 05:59 PM
YSILT1's Avatar
Default 11.5 AFR at Idle
I am trying to help a friend tune his car at the dyno. No matter what I change on the injector flow rate the car runs at 11.5 : 1. The long terms are at -15 then go to -8.
My question is is there a desired AFR in the ECM that might be messed up. The dude bought the car used so who knows who tuned it. Also does anyone have a stock 99 M6 file that I could get so I can compare.
Thanks. I am using EFI Live.
Old May 14, 2009 | 06:28 PM
Patrick G's Avatar
LS1 Tech Administrator
NB O2 sensors could be shot. Could have a vacuum leak, an exhaust leak, a ported MAF, or any number of variations from stock that can monkey with his A/F ratio.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old May 14, 2009 | 06:42 PM
YSILT1's Avatar
I put a stock maf back in. the O2's match the dyno afr's. The car has 42 lb injectors with a Procharger. We have not started any other tuning since I cant get it to work at idle or cruising speeds.
The oil is way fuel saturated. I am going to see if that helps. We know in about 20 min.
I just found out that he drove the car for 2 weeks with no tune. So I think maybe the oil might fix it.
thanks for the input.
Old May 14, 2009 | 07:59 PM
shoemike's Avatar
EFILive Tune File Repository - Stock Tunes
Old May 15, 2009 | 02:42 PM
YSILT1's Avatar
Found the problem late last night. One of the fuel injectors was leaking while the car was running.
Thanks for all the help.
