Efi live shift point change
Old May 18, 2009 | 05:08 PM
JASON11WS6's Avatar
Default Efi live shift point change
How do you change shift points with EFI live?
Old May 19, 2009 | 09:06 AM
wait4me's Avatar
You can just go to the transmission tabs and add or subtract values there, or you can make it a global change by going to H0101 and then hit Speedo calculator at the window, Then hit the shift point correction tab and then enter in a percent you want it changed by, then hit apply. It will then go thru all the trans tables and add or subtract your value.
