Running Lean
Old May 20, 2009 | 06:52 PM
8675309's Avatar
Default Running Lean
So I've been running lean lately in the 2 and 3 cylinders. Could I need a tune to fix this? Also I have a really bad exhaust leak at the collectors. So could that have an affect on it? The leak is close to by 02 sensors. Also I dont have rear 02's. My mods are lid, h pipe, and longtubes if that would have any affect on it too. Or what else could it be?
Old May 20, 2009 | 09:25 PM
BadgeZ28's Avatar
If you are not throwing codes, the rear O2 sensors have been deleted from the pcm. Get the leak stopped. It could be throwing off the existing sensors. If that doesn't solve the problem maybe swap injectors to another cylinder and see if the problem moves with them.
