Need help fixing DTC - P1626C
Old May 26, 2009 | 08:35 PM
Schlib1's Avatar
Default Need help fixing DTC - P1626C
My scan tool shows the the code P1626C and reads FUEL ENABLE SIGNAL NOT RECEIVED. After further research on this site, the code has to do with the Theft Deterrent... Do you guys have any ideas how to fix this problem? Any ideas are greatly appreciated... Thanks.
Old Jul 2, 2009 | 06:47 PM
brianfromhawaii's Avatar
bymp this
Old Jul 2, 2009 | 07:09 PM
poconojoe's Avatar
He's dealing with a V6 not an LS motor. The BCM isn't sending the signal to the PCM. Most likely it isn't vranking over either. He needs to do a learn, but needs to clear the error codes from the PCM first. If its a Monte or Impala, it most likely needs an ignion switch
