ABS INOP and Brake Lights
Old May 29, 2009 | 12:14 PM
greg_74's Avatar
Default ABS INOP and Brake Lights
Ok so I've had it where my ABS INOP and E-Brake lights have come on either when I start the car or when I'm just going down the road. Also, my ASR light stays on if I hit the switch to turn it off. However, the lights usually turn off after I turn the car off and start it again. The brakes feel fine and I checked and added some brake fluid and it didn't solve the problem. Any ideas what could be causing them to come on?
Here's what the gauges look like when they are on...
Btw if there is another thread or something on this just point me in that direction, with a link, I didn't want to search because I'm in kinda of hurry. Thanks guys.
Old Aug 22, 2009 | 03:34 PM
robster's Avatar
i have the same problem
Old Aug 22, 2009 | 05:55 PM
tsench's Avatar
i also have same problem never seem to figure out maight thinking out tune it out
Old Aug 22, 2009 | 07:40 PM
95'FiReChIcKeN's Avatar
By any chance, have you upgraded the wheels/tires recently?
Old Aug 22, 2009 | 07:46 PM
RickClarke23's Avatar
I have the same problem.
Old Aug 24, 2009 | 02:22 PM
greg_74's Avatar
Well the problem with mine is the control module which for them to fix at the dealer is $950 so I'm not going to fix it and just run without ABS because its not worth it imo.
Btw from what I've read you can't just tune the lights out, you either can leave it as is, fix it which turns the lights off of course, or delete the whole ABS system but that doesn't turn the lights off either.
