Cylinder balance test
I wanted to try to cylinder balance test since it intrigued me but I cannot find it. Judging by the manual it should be located in the drop down menu with change vin and all that but its not. I found the box to set the idle, turn injectors on/off, and all that but not to run this test. The crank relearn is there but that's it.
Any ideas?
DVT
Change VIN
Oil life reset
In DVT all that's there related to engine are:
Fuel trim reset
Crank angle relearn
Evap service test
I just updated today just to be sure.
Also mine doesn't say "LS1/LS6 controller" or "Allison controller" is just says "DVT". Weird and frustrating.
