Signs of bad coil.
Old Nov 10, 2003 | 09:20 AM
boomcase's Avatar
Question Signs of bad coil.
What are the signs of bad coils or a coil that is going out. Ignition failure I guess is what im asking. Would it include lose of high rpm . Thanks
Old Nov 10, 2003 | 09:27 PM
WS6FirebirdTA00's Avatar
check you plugs and wires first, that was my problem
Old Nov 11, 2003 | 10:09 AM
boomcase's Avatar
Plugs are all the same color, TR6s, wires Look to be ok to burning on headers and so fourth. The car just turned 20000miles.
Old Nov 11, 2003 | 11:58 AM
my deal was my plugs werent pluged in all the way. what about your air fuel at WOT? my lean condition caused my car to feel like it was slowing down but i couldnt hear detonation. im just throwing stuff out there really. if i were u and thought the coil might be bad then jsut pull off the caps on the coil and put an old wire and plug in there and see if they all arc the same...
Old Nov 12, 2003 | 12:52 PM
2001SS#3013's Avatar
You will know if a coil is bad. It will throw a code.
