surge help
Old Jun 19, 2009 | 10:38 PM
had20z's Avatar
Default surge help
I have a 01 silverado, that I have put the L92 crate motor, long tube headers, 90mm tb, and a comp cam the specs are 222/224 566/568 112lsa.... im using the lingenfelter 54 to 24 reluctor converter....a fully built tranny with a 2800 stall...
the truck as is, will start and surge/swing from 500-1600rpms and when it does this the truck dies....
other times if you give it a little gas and let it "catch" it self the truck will start to idle but with start to swing less from 500-1000....
What cause it to Surge?
Old Jun 20, 2009 | 02:58 PM
MUSTANGBRKR02's Avatar
DO you have it tuned at all or have a tuning app?
If so then you need to up your RAF then start from the begining look up top for the stickies
