efi live - lm1 hook up
Old Jun 29, 2009 | 09:20 PM
JASON11WS6's Avatar
Default efi live - lm1 hook up
Okay, I am planning on hooking my lm1 up to my efi live so I can record my afr. Just want to make sure I'm doing this right. First I have to update my lm1 to show 1v=10:1afr and 5v=20:1afr. Then I just hook up the analog cable from the lm1 to a 2 pin connector and plug it in all the way to the left on the efi live right? Do I ground that extra wire? Is their anything else I'm missing or doing wrong?
Old Jun 30, 2009 | 01:00 AM
Goldfinger911's Avatar
Doesnt your LM have a serial output? You should use that. Much more accurate and no voltage or grounding issue possibilities. Check out the EFILive forums for details.
http://forum.efilive.com/showthread....ht=lm-1+serial
Old Jun 30, 2009 | 09:21 AM
rpmauto's Avatar
serial cable is the way to go, i think TA Quickness sells them for the Lm1
Old Jun 30, 2009 | 09:24 PM
JASON11WS6's Avatar
So if I plug the serial port to my pc, my efi live will pick it up and read the afr.
Old Jul 1, 2009 | 08:15 AM
rpmauto's Avatar
the serial cable goes from the wideband to the v2. You will have to add the pid to your dashboard.
Old Jul 2, 2009 | 10:03 AM
shoemike's Avatar
If you are using V1 analog is your only option.
"The LM-1's second analog output is factory programmed to provide a linear output between 1V and 2V for an AFR of 10 to 20"
This matches the EFILive predefined PIDs for the LM-1.
Connect the second analog output to Flashscan.
