need help 110 lsa bad thanks
Old Jul 6, 2009 | 10:59 AM
nofordfan's Avatar
Default need help 110 lsa bad thanks
need help 110 lsa bad ok i have a 94 lt1 with a 510 520 lift 230 236dur cam 110 lsa ported heads and lot of boltons 410 gears 9 inch and th350 trans my problem is the timing has to be advanced to 52 for it to run good i was told 110 lsa is to tight and the injectors cant pulse right is this true and is there a way around this or do i have to get a 112 lsa cam thanks
