Lets get my 404 ls2 optimized
Old Jul 9, 2009 | 11:39 PM
pHEnomIC's Avatar
Default Lets get my 404 ls2 optimized
Ok well I just got a 404 ls2 installed in my car. Running torquer v3 cam, 241 heads, and ls6 intake. (i plan to do a h/c/i within the next year but the shortblock was too expensive to do at this moment).
My car ran awesome before the 404 was put in till i spun a bearing. I simply changed the displacement and it seems to be running good and strong but I feel that im leaving some on the table.
Lets look at part throttle at the moment as I am still breaking it in and dont want to get crazy with the rpms yet.
What should I do spark and fuel wise to optimize power? I realize i need a load bearing dyno to get 100% on the money but someone has to have some input.
Also, i believe my compression is 11.5 which is higher than it used to be if that makes much difference.
I dont have a WOT log yet because i want to make sure its broke in well before i beat on it.
This link to get the tune and log:
http://www.hptuners.com/forum/showth...579#post177579
Old Jul 10, 2009 | 02:35 AM
ringram's Avatar
Originally Posted by pHEnomIC
I realize i need a load bearing dyno.....
You answered your own question dude.
Old Jul 13, 2009 | 03:59 PM
Doc99SS's Avatar
Not sure I understand what you are doing. First of all, you do not tune for optimized power when tuning part throotle. Or am I wrong on this matter?
After I installed my 402 LS2 stroker, I tuned the idle, then the part throotle which to me means that I tuned the drivibility by driving around at various speeds and load cases, but never got into WOT. I tried to put the PCM into as many FTCs that I could, and data log as I drove. I came back home with a very big file.
For the part throotle tuning, I simply let the fuel trims guide me in tuning, first the MAF table, then with the MAF disabled, I tuned the VE table. For the MAF table, positive fuel trims means that I need to increase the values in the MAF table. The reverse is true. And you best have a smooth function here. No steps.
