LC1 + Gauge + HPtuners...
I know the LC1s wideband output goes to both the gauge and the EIO input. And I know the second ground on the LC1(not the heater ground but the second ground) is supposed to go to the ground port on the HPT. So Should I just ground the LC1 and the gauge at the same spot on the chassis, and then ground the LC1's EIO ground to that spot as well whenever I have it in the car?
Also, Innovate says I should ideally ground BOTH LC1 grounds at the same spot, ideally soldered together as opposed to using two eyelets. But then I read on here at HPT forums that the two grounds should be far away from each other...IE Heater ground to the cylinder head, and the other ground to a chassis ground somewhere in the car. Which is it?
I'm gonna wire it to HP tuners using that same ground terminal, and if there's no offset issues, I'm gonna rewire it cleaner and just make it portable like the LM1.
