closed vs open loop speed density
Old Jul 19, 2009 | 07:35 PM
Tally TransAm's Avatar
Default closed vs open loop speed density
is there a benefit of one over the other in a turbo car
im building my hot side next week and im trying to decide if i should add the front o2's
thanks
Old Jul 19, 2009 | 10:10 PM
Texas_WS6's Avatar
I would add them and try to utilize them. The advantage as I see it is, there is now way for the PCM to make fuel adgustments in open loop, but it will in closed loop. When you go WOT the pcm sets the STFT to 0 but it does add the LTFT to the WOT run. This adjustment is to correct fueling do to altitude and barometric pressure. I guess you could say, when the engine is correcting STFT it is learning the conditions of the moment and it applies this at WOT. In open loop only, it does not make the minor fuel adjustments and therefor the pcm will not make LTFT corrections. In this situation you would always have to use your tuning software and WB to make the minor adjustments caused from alltutude and barometric pressure changes.
Old Jul 20, 2009 | 05:52 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
thanks
If for no other reason, I would put them in just to correct the innacurate fueling that can be caused in heavy traffic due to IAT sensor heatsoak.
Old Jul 24, 2009 | 09:13 AM
cablebandit's Avatar
bingo!! I would have mine in closed loop at sub 2000rpms if i didnt run c16 at the track. (would kill the sensors pretty quickly)
gametech: using efilive cos...do you know if iat/fueling correction table affects WOT as well? I guess I should just try it...mine goes lean at idle-p/t with heatsoaked IAT sensor.
Old Jul 24, 2009 | 05:06 PM
gametech's Avatar
I have no idea. I'm using HPT.
Old Jul 25, 2009 | 07:43 AM
ringram's Avatar
Yeah A00014 table will work at any point.
IMO CLSD is very good. Dont run LTFT, just run STFT's
Old Jul 25, 2009 | 07:51 AM
Black02SS's Avatar
If you have questions Ryan just shoot me a PM.
