Getting tacho to work with E40 ecm
Old Jul 22, 2009 | 07:30 AM
Ls2 cruiser's Avatar
Default Getting tacho to work with E40 ecm
Howdy, This is my first post on this website, but I thought members may be able to help. I have a supercharged Ls2 in a 2000 model Landcruiser ute with a built 4L65E auto. I am using the E40 ECM and T42 trans computer. I am having lots of trouble selecting the correct HP tuners setting for the tacho output so that I can recalibrate the original landcruiser tacho. Crank and serial seem to give hardly any signal. There are apparently 3 settings. Can someone tell me which one we should use. Cheers Russ
Old Jul 23, 2009 | 11:03 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
Crank, 15, 15, 300ohm resistor pulled up to 12volts on the signal.
Old Jul 23, 2009 | 07:05 PM
That sounds like the way to fix the E38 ecm. Are you sure it works for the E40? Cheers Russ
Old Jul 24, 2009 | 03:58 AM
Crank output seems correct for the tacho for the E38 ecm, but does not seem ok for the E40 ecm. My loom maker autoelectrician in Sydney and I have both come across this. Are you positive. Cheers Russ
Old Jul 25, 2009 | 10:19 AM
LS1TECH Sponsor
That is what I did for the E38, so I guess for the 24x crank, use 6 and 6, not the 15
