Spark Retard Signal wire???
Old Jul 26, 2009 | 03:57 PM
RENE'S RAGE's Avatar
Default Spark Retard Signal wire???
What does this wire do? It goes from the PCM connector C2 pinout #53, Gray/Black wire. To the ING RETARD pinout #19 on the Traction Control Module. I am eliminating the ABS and Traction Control on my car. Does this wire send a signal to the PCM telling it to retard timing. Do I need to remove this wire from the PCM or what? Hell. I'm even confusing myself. Thanks George
Old Jul 27, 2009 | 07:34 PM
Come on, somebody please.
Old Jul 27, 2009 | 10:30 PM
shoemike's Avatar
I can's say for sure but I thunk it tells the PCM the the TCS has detected wheel slip
and the PCM will pull xx amount of timing at xx RPM.
There are three tables related to TCS spark retard.
Are you removing the TCS/ASR unit?
Old Jul 28, 2009 | 05:22 PM
Yes, I'm removing TCS and ABS. Do I need to just remove the wire from the PCM or ground it out or what. I'm in the process of removing all wires I don't need from the engine harness and PCM. I just don't want this to pull timing.
Old Aug 1, 2009 | 10:41 AM
Still re-searching but found nothing. HELP
Old Aug 1, 2009 | 12:19 PM
shoemike's Avatar
I have head of some people just pulling the fuse on the
ASR/TCS module to "delete" it.
I bet if you just unplug it that will be good enough.
if it's not there how can it tell the PCM to retard spark?
Old Aug 2, 2009 | 10:46 AM
That's what I'm thinking to .
