P0200 anybody?
Old Nov 19, 2003 | 03:39 PM
n2o's Avatar
n2o
Default P0200 anybody?
Has anyone ever had this code? It is a code for an injector malfunction code, but it is not cylinder specific. I ran some injector cleaner through a few gallons of gas (the light goes off) and then shortly after, I had added a couple more gallons of gas and the s.o.b. comes back on. The main sympton is missing under higher rpms. What do I need to do? Change injectors, what?
Car is 2001. hc, bolt-on car
Old Nov 19, 2003 | 05:58 PM
Texas Terminator's Avatar
yea, just had this same problem over on the truck side. he reflashed his PCM and it fixed it.
Old Nov 19, 2003 | 06:10 PM
GrannySShifting's Avatar
make sure they were all plugged in, no terminals corroded
Old Nov 19, 2003 | 11:05 PM
wrencher's Avatar
wrencher
Check the resistance on them as well(injectors)
Low resistance causes high amp draw thru the PCM driver & then problems.
