Reprograming a 1999 LS1 PCM for a 2004 LS6 ?
Old Nov 20, 2003 | 09:53 AM
SoulCollector's Avatar
Default Reprograming a 1999 LS1 PCM for a 2004 LS6 ?
Can i make a (automatic transmission) LS1 PCM and wiring harness work with a manual LS6 in an older car ?
I need to know fast !!!
/JW
Old Nov 20, 2003 | 09:59 AM
Texas Terminator's Avatar
good question. a similar question came up elsewhere in here. something about the build/software versions matching but that was auto to auto. if you are putting it in a non-computer car (ie with BCM, ABS, etc), i don't see why it wouldn't. you may have to disable some of the tests that are run.
Old Nov 23, 2003 | 08:22 AM
Thanks !
So i guess the wiring harness will fit the LS6 then (since GM sells the LS6 as a replacement for a LS1 in corvettes etc i guess thats quite clear)
I've been in contact with "Speed Scene Wiring" and they told me this when i asked them about this:
// THE LS1 WIRE HARNESS MOD IS 455.00 AND THE COMPUTER PROGRAM THAT REMOVES THE VEHICLE ANTI THEFT AS WELL AS ADDING 26HP IS $295.00. PLEASE INCLUDE 35.00 FOR RETURN FREIGHT. //
Sounds painfully expensive... can't i do this reprogramming myself with carputings LS-1-Edit ?
Is there some where one can get hold of the wiring schematics for the LS1/LS6 in a Camaro,T/A or Corvette...any good books to read ?
