DBW pedal and TAC module differences
Old Aug 25, 2009 | 10:19 PM
dmaxben's Avatar
Default DBW pedal and TAC module differences
Ok so Im piecing together my setup thats going in my offroad buggy.
99 4.8 mated to a TH400 (used the spacer etc..)
I converted it to drive by wire.
Im not sure what year the [truck/SUV] harness is from. It has RVC (regulated voltage control, the "smart" alternator control module) so that means it has to be at least a 2005, and at the most a 2007 because its an LS1-style harness (GMT-800). I might take the part number to the GM dealer and see if they can look up what applications it was used in.
I bought a TAC module and pedal assembly from a 2005.
I know they switched to the new style pedal in 2006, and I would assume a new TAC module too?
Heres where I get confused...im looking at the GM service manuals and it seems that from 2003-2004 the pedal had 3 sensors. Then in 2005 it went to 2 sensors (but still the old style pedal assembly with the external springs and pivoting pedal etc), and then in 2006 they went to the completely new pedal assembly (which also has 2 sensors).
I know the TAC module will care what kinda pedal its talking to, but does the PCM care what TAC module its talking to, as long as the PCM is an 03-07 and the TAC module is an 03-07???
Why im asking is because I want to run a manual trans OS in the PCM because im running a TH400. But the only manual 4.8 OS I can find (in EFILive format) is from a 2004...which supposedly has the 3 sensor accellerator pedal assy,
If I use the 2004 PCM is it going to care that its talking to a newer 2005 TAC module [that only monitors 2 accellerator pedal sensors instead of 3]??????
Im guessing it wont matter....because ive looked at the schematics from 2003-2007 TAC modules, and the PCM <---> TAC wiring is identical. Only difference is the TAC <---> pedal wiring itself on the 2003-2004, 2005, and 2006-2007 trucks.
I suppose I could just go ahead and try it, but I just thought I would check to see if anyone knew the answer for sure...
thanks
Ben
Old Feb 20, 2011 | 08:36 AM
LilJohnnyB's Avatar
Hey ben,
I know its an old post, but what did you find out? I have ran into the same question, as I piece together the 04 6.0L setup in my 57.
Johnny
