Can HP tuners be used on multiple laptops?
Old Aug 27, 2009 | 01:59 PM
veee8's Avatar
Default Can HP tuners be used on multiple laptops?
Helping a buddy out with some tuning. He bought the MPVI Pro system new. Can the software be loaded on 2 or more different laptops at the same time? We don't want to run into any registration issues with loading the disc on more then one laptop. What is the procedure, load the software, and enter in a registration key?
Old Aug 27, 2009 | 02:12 PM
dan@masportspeedshop's Avatar
LS1TECH Sponsor
Exactly. You can use as many computers as you want, but you must have the proper application key registered and use the one interface cable for which the App Key is asigned. I use two different interface cables on the same laptop (which requires changing the app key...I have my reasons), and also have two different laptops that I use with both interfaces. NEVER had a problem...Tip my hat to HP Tuners for the good work!
JonCR96Z's Avatar
You can put it every laptop in the world. It's the cable that has the license info.
Load the software, then connect to the MVPI and enter the key.
Old Aug 27, 2009 | 02:39 PM
veee8's Avatar
Cool thanks guys, I don't miss the days of LT1Edit!
