Important info about using BS3 with 16V systems
https://ls1tech.com/forums/forced-in...ne-season.html
My BS3 has been repaired. Also learned two nuggets of info relating to my problem which I want to share.
My problem was a blown out IAC and secondary chip. This is caused by charging a 16V system with it powered. I always try to kill the main power switch on the car when charging (everything including BS3 is on the switched side) but must've forgot it once. MAKE SURE YOU DON'T CHARGE 16V BATTERIES WITH THE BS3 POWERED
Coil dwell with 16V systems (including the Caspers volt booster) DO NOT USE MORE THAN 4ms DWELL TIME. Upping to 6ms dwell is a common thing done at these power levels, but this is only for 12V systems. If you use 16V battery or up the alt voltage to 16V at WOT via the casper volt booster then set max dwell to 4ms.
BS3 is adding this info to their FAQ section since it was definately not common knowledge until now...
Bottom line your getting her fixed up and thats great bri....
