MAF Tuning Help
1.) Disconnect MAF and disable MAF error code, forcing PCM into Speed Density mode.
2.) Tune VE table using LTFT as feedback, shoot for 0% trim in all cells. This takes lots of miles, in lots of RPM/load variations.
3.) When this is done, re-connect the MAF and re-enable the MAF error code.
4.) Tune MAF table to get LTFT back to 0%.
When tuning the MAF, set the High RPM Disable from 4000 RPMs down to like 100RPMs to put the car 'on the MAF' for it's tuning. Put it back when you get done.
