Wideband going lean??
I al thinking:
A) Tune-needs it from the TR224
B) Injector O-rings, top ones maybe sucking in air, as since I replaced them but not using the 9/16x5/16 at 1/8" I used the next size smaller, maybe they are able to bring in enough air but not leak? And I only noticed this after servicing my NXL for bad orings!
C) A leak somewhere after MAF, but I havent messed with anything other than the O-rings and since then is when it acted like this, that and the weather, cooler, and damp-been raining all day.
Any other suggestions wlecome.
That is, unless you have an exhaust leak you don't know about.
Good luck,
Andrew
I al thinking:
That's a major increase in air flow.
Doesn't seem like reversion would lean you out...probably would push it rich at idle. Poor efficiency at idle.
I think it wants more fuel.
FWIW. joel
