a/f ratio conversion?
Old Sep 21, 2009 | 01:11 PM
lsxmalibu's Avatar
Default a/f ratio conversion?
I have a digital a/f gauge and was wondering if there is a chart that shows voltage to wide band numbers?
Old Sep 22, 2009 | 04:28 AM
dsmlights's Avatar
what type of gauge. most of them have a manual and shows the voltage for the a/f most of these gauges run from 0-5v
Old Sep 22, 2009 | 07:11 AM
lsxmalibu's Avatar
I have two, a 0 to 1 volt gauge and DynoTune A/F Ratio lean switch, Im at
.870 on the bottle and was trying to see what that is for a/f
Old Sep 22, 2009 | 07:21 AM
SweetS10V8's Avatar
Is it a wide band???
870mv sounds like a narrow band and you wont be able to convert because narrow bands aren't accurate except for a small range around 14.7:1
Old Sep 22, 2009 | 08:43 AM
lsxmalibu's Avatar
stock narrowband. I thought I saw a chart once that showed approx a/f ratio to mv's. like 14.7 was 450 mv's
Old Sep 22, 2009 | 11:07 AM
Frost's Avatar
There may be a chart, but it's garbage.
You cannot accurately measure much of anything away from stoich with a narrowband sensor. That 'gauge' is just a lights show.
Old Sep 22, 2009 | 12:01 PM
BuffJoeyD's Avatar
I get tired of all the people with narrow band gauges running - They are for the Stock PCM to try and contol fueling, not for an AF ratio. 450 is close to Stoich when the sensor is in the fqactory original location in the stock manifold- anything above that is richer
Old Sep 22, 2009 | 12:17 PM
lsxmalibu's Avatar
Im not using it for tuning, its a lean shut down switch, I just wanted an idea of what my voltage is close to. The chart I have for the switch seems off....
 Michael S. Palmer
Old Sep 22, 2009 | 12:24 PM
Frost's Avatar
It IS off... That narrowband will report (significantly) different voltages for the SAME AFR as it's temperature varies (among other things)... Merely moving it's placement in the exhaust will change it's reading as well.
Old Sep 22, 2009 | 12:41 PM
lsxmalibu's Avatar
