NEED HELP! Codes!
Old Sep 25, 2009 | 08:03 PM
mattslightning's Avatar
Default NEED HELP! Codes!
My car keeps throwing these 2 codes! I dont know why or what else I can do. The car has a new IAC and a new TPS and a new MAP sensors! Both codes are thrown at the same time. The codes are P0121 and P0507. Any help would be greatly appreciated!
Old Sep 26, 2009 | 06:01 AM
davidws6's Avatar
Default Codes
P0507 is "Idle Control System RPM Higher Than Expected"
P0121 is "A code P0121 may mean that one or more of the following has happened:
* TPS has intermittent open or short internally
* Harness is rubbing and causing an open or short in the wiring
* Bad connection at the TPS
* Bad PCM (less likely)
* Water or corrosion in connector or sensor"
All your grounds connected good ? Does it idle fast ? Did you notice anything when these codes started popping up ?
Do you have a way to test the sensors with some kind of scanner to verify their functionality?
Verify that your TPS is reading 0 volts when the TB is closed ....
Old Sep 26, 2009 | 06:37 AM
I'm thinking it's a wiring issue or a bad PCM. It started to do this after I got a mail order tune. Had it it dyno tuned since the mail order and it still throws the code randomly. I will check the wiring again.
Old Sep 26, 2009 | 07:36 PM
Bump!!!
Old Sep 27, 2009 | 03:17 AM
So tonight I took the car out. Drove it over 100 miles and no light. Pulling into the garage it throws a check engine light. This time it's the P0507 light only. I'm getting so tired of this! Any more ideas?
Old Sep 27, 2009 | 06:04 AM
69LT1Bird's Avatar
Follow these steps:
P0507
