edit fails read ?
Old Dec 2, 2003 | 07:21 AM
megathumpzilla's Avatar
Default edit fails read ?
Edit is having com failures on my pcm. Tech 2 and autotap can both read the pcm, but when I hook edit up it fails. It does an "exchange security keys", the first thing it does, then looses communication, over and over.
I can read a locked Wright pcm, or get all the data and then it shows it's locked. I put a new pcm in to tune, but can't read from it. The VIN is wrong, and was planning on turning off vats with edit, is this what's causing it to fail?
