Threw a AIR code.
Old Oct 1, 2009 | 07:21 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Default Threw a AIR code.
http://gearchatter.com/viewtopic9356...7d34ad73273c37
This is due to removing the Pump so I understand why. I had not before or short after the removal is wipe out the DTC codes with my scanner. I did it last night as I finally got around to it. I thought I had dead o2's but turns out they are fine.
My question as I put cycles on the car to get everything reset, with the pump removed but the distribution valve/block in the back still on and the lines ran to the header, do you think its likely the code will resurface?
I know there is a link about Drivecycles and what it takes to ready all the systems, if someone has that, can you please post it.
I have scannable emissions coming up and I just want everything perfect. Worse comes to worse, I can toss the pump back in and plug it in while I get it ready.
The MIL light did not illuminate on the 1st drive.
Old Oct 1, 2009 | 08:10 AM
06MonteSS's Avatar
LS1Tech Sponsor
here ya go man....
http://obdii.com/drivecycle.html
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Old Oct 1, 2009 | 08:22 AM
Internet Mechanic
Originally Posted by 06MonteSS
Perfect, thanks!
Old Oct 2, 2009 | 07:38 AM
Internet Mechanic
Not that it was not unexpected. AIR code came back, now I gotta dig for the pump so it can energize and I can get through emissions.
