e38 ecu speedo and tach problems
Old Oct 6, 2009 | 09:47 PM
pillagenburn's Avatar
Default e38 ecu speedo and tach problems
OK, so here are my issues on a 1994 Firebird with LY6 vvt motor and M12 t56 installed:
speedometer: I have my t56 VSS hooked into my e38 at the vss lo/high input (aka replicated TOS) on my ecu. I have the settings in the ECU (via hptuners) set to what would be factory on a normal f-body with 17" wheels. I looked up stock tune files and copied the settings over.
The problem is that when I drive, if I'm moving the needle on the speedo peggs or goes up REALLY sharply then peggs - i adjusted settings in hptuners and nothing seemed to change that behavior. When I stop, though, the needle on the speedo goes to zero... very weird!
The tach i have hooked directly to the tach output on the e38 ecu... but i get nothing, no activity of any kind - is there something I'm missing? I heard of people saying something about a 12v pull-up resistor but I can't find anything on it.
if anyone has any suggestions that'd be great - thanks!
Old Oct 8, 2009 | 09:28 AM
mr220v's Avatar
Got the speedo figured out. Now just the tach.
Old Oct 8, 2009 | 09:55 AM
Schwanke Engines's Avatar
LS1TECH Sponsor
680ohm resistor between the 12v ignition wire and the tacho input wire which basically jumps a 5v signal upto 9v and there you go a tach signal
Old Oct 8, 2009 | 10:16 AM
mr220v's Avatar
That's what I'm reading now. I'll try it tonight. I found your previous post about this. Do you have a specific resistor type that you'd recommend?
Old Oct 12, 2009 | 08:46 AM
mr220v's Avatar
The resistor worked.
Old Oct 12, 2009 | 10:42 AM
LS1TECH Sponsor
Sweet, What's you address so I can send an invoice?
Just kidding, glad to help.
