weird wideband readings
Changes:
SLP maf to a stock maf
added ftra
tci 3500 stall to circle d 3800
stock tb to ported tb
high flow fuel rails
2.5" Y pipe with a spiral flow to a 3" Y with dual cutouts and a dynomax bullet
msd wires
tr6's to br7ef's
walbro 255
After the exhuast went on the car ran horrible and would pop through the exhaust at anything over 2500 rpm and shake the car, The next day I changed the plugs and wires, they were gapped between .015-.040
. I gapped the br7's all at .030 and it made the shake go away but it still poped through the exhaust so I figured it might be going lean so I hooked up a fuel press. guse to the rails and it was showing 58-60psi steadily. Finally yeterday I hooked up my LC1 that I had on my old ss. I made sure all the grounds are good and grounded the blue wire to the driver side head. The guage reads around 19-20 to 1 most of the time but will dip down to 9.5-10 to 1 sometimes and jump right back up to 19. Could it be reading right and my car has that bad of a tune on it or is something wrong with the wideband?
