How is a/f calculated by the PCM?
RPM = 5652
A/F Ratio = 11.4:1
02 B1 = 845 mV
02 B2 = 880 mV
On the wideband dyno, A/F was about 12.9 at this rpm. Since then I've added 5% to the IFR table. I've got 42# injectors, longtubes, ORP (and a number of other mods).
Based on the 02s, it looks a little lean. Based on the A/F calculation from the PCM it looks rich. Which one is correct? What causes the inaccurate reading of the one that's wrong?
*I've had zero KR on a WOT run. I have had a couple spikes of 1-3 degrees below 2000 RPM but I'm thinking that this is false knock. LTRIMS averaged about -8 crusing around before I adjusted the IFR table by 5%. They now average about -4.
Either way, I edited the timing tables as recommened by slowhawk, and edited the VE tables per ls1tuning.com. The surge and high idle have all but disappeared.
Only thing left right now is to install the fuel regulator from LPE and I'll get it back on the wideband. Then the nitrous will come
