Preogramming LC1 Analog Output
Old Nov 14, 2009 | 09:57 AM
C_Rules's Avatar
Default Preogramming LC1 Analog Output
How long does it take to program an LC1 analog output? I was trying to program it and it was taking forever. I tried to get out of it but it then crashed my pc.
Old Nov 14, 2009 | 01:44 PM
Doc's Avatar
Doc
It takes as long as cycling the power. Once you have programmed the new values the LC-1 will sit there in programing mode until you cycle the power for the new settings to take effect.
Old Nov 14, 2009 | 02:25 PM
C_Rules's Avatar
What do you mean by cycling the power?
Old Nov 14, 2009 | 03:18 PM
bmax's Avatar
Turn it off, then back on.
Brad
Old Nov 14, 2009 | 04:10 PM
C_Rules's Avatar
how much time do i give it before i turn it off. do i just hit program and then turn the switch off? also just want to confirm whether i program it with the car running or just with the key in the on position?
Old Nov 14, 2009 | 04:42 PM
shoemike's Avatar
You just need to have the LC-1 powered on, do it with the engine off.
I hit the program button and wait 5 seconds then
turn it off for 10 seconds before I turn it back on.
It does not give confirmation dialog box after wards but it will still be programmed.
Old Nov 14, 2009 | 04:46 PM
C_Rules's Avatar
cool, thanks everyone.
Old Nov 14, 2009 | 06:54 PM
C_Rules's Avatar
mission successful. programmed the output and logging through my pcm now. since its an lt1 i used the ac pressure sensor to send the signal from the lc1 to the pcm.
