MAF Voltage
I believe the red wire should read 12v. It looks low to me. Is the 11.12v adequate?
Is the .241v for the yellow wire correct for being at "ignition start". I believe it should be 5v, but is the 5v reading when the engine is turned on?
Checked the 20A Engine Sensor fuse and it looks fine.
I also noticed on my cluster that the voltage is reading low. This may be a grounding issue.
