Max Timing for LS1
Old Nov 19, 2009 | 05:48 PM
TomM's Avatar
Default Max Timing for LS1
What is the maximum timing allowable for a stock LS1 with LS6 intake and headers, everything else bone stock....
T,
Old Nov 19, 2009 | 06:57 PM
Mike@ZMS's Avatar
It totally depends on your car. Some cars can handle lots of timing, others will knock and ping all over the place and just generally not be happy with much over stock.
Get your car on the dyno, use a wideband and fully tune it. When my car was stock (lid and filter were the only mods) I put down 325whp on the first past. 2 hours of tuning later and I was making 340whp. Even a stock vehicle with manifolds can benefit from a good dyno tune.
Old Nov 19, 2009 | 07:03 PM
slowlsx's Avatar
Usually between 25-28... Some like more , some like less. Just because you have 32* at WOT and there's no knock doesn't mean it's liking it. Like the guy said above me throw it on the dyno and make some hits! Good luck
Old Nov 20, 2009 | 10:51 AM
TomM's Avatar
Thanks for the replys, don't have dyno access, and not in a position to put it on there yet, just wanted to know what not to exceed....
T,
Old Nov 23, 2009 | 10:33 PM
Patrick G's Avatar
LS1 Tech Administrator
Good safe place to start is 26 degrees at peak torque (4800 rpm) and ramping up to 28 degrees by 5600 rpm. You can then experiment with more timing or less. The 26/28 is very common for stock LS1 running 91-93 octane. Don't be surprised if your power doesn't change much with 2 degrees more or 2 degrees less timing. 26-28 degrees is the sweet spot for most stock motors.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Dec 1, 2009 | 10:55 AM
TomM's Avatar
Hey Patrick, see you are from Victoria, grew up there, still have family there too....
So would the tables be the same in low and high octane, and can I run either fuel......just cut and paste to the same in each table....if you have time, can you look at my tune file......
T,
