I need an FI starting tune
Old Nov 26, 2009 | 01:12 PM
WS6 GreeN's Avatar
Default I need an FI starting tune
I just finished a turbo build and now I'm getting ready for the tuning stages. I've searched this forum and the HPT forum for tunes I could use for a base tune but haven't really had much luck. The tunes I've downloaded, some of them the VE tables weren't changed above 105 kPa and I can't help but think those values will go up a good bit depending on the boost you're running. I think I've done OK on the timing table but need a little guidance on where to go with the VE. I'm going to start tuning with 6 psi and go up. I do have a wideband so that's not a problem. Any insight is greatly appreciated.
Old Nov 30, 2009 | 08:55 PM
cablebandit's Avatar
do you have ve tables to be filled after 105kpa? i dont have hpt
