DTC code P1351 Help needed!
Old Dec 13, 2009 | 11:38 PM
bad_408_vert's Avatar
Default DTC code P1351 Help needed!
Hey guys,
Car is a 3.8L camaro with 62k miles.
So i drove the car home and SES light came on, the p1351 code came up on my scanner.
Its something to do with an open circuit, ICM wiring voltage for coil 1&4.
Its beyond my comprehension on how to address this since the coil, ICM are fine.
While driving home it didn't accelerate right, very slouchy coming off a red light. RPMs were up to 2900 and car was only going 20mph but it picked up speed gradually.
I really appreciate it if someone can shed more light on this before i have to take it to shop again.
Thanks!
Old Dec 14, 2009 | 06:18 PM
BUMP
please someone help with this, this is only cAr I have to get to work.!!!!
Old Dec 14, 2009 | 06:24 PM
69LT1Bird's Avatar
How do you know the coils and ignition control module are fine?
More info on the car would be helpful, year etc.
Old Dec 14, 2009 | 06:45 PM
eseibel67's Avatar
Probably the ignition control module (under the coil packs).
Other possibilities are wiring between PCM and ICM or PCM itself.
Old Dec 15, 2009 | 01:36 AM
The car is a 2001 camaro 3.8l
I replaced the ICM and all 3 coils just to test if any of these 4 things were the problem.
But the ses light with the code p1351 came back on again.
Message on scanner is saying something about voltage being too high on coil 1&4.
Thanks fellas!
Old Dec 15, 2009 | 06:12 AM
69LT1Bird's Avatar
Here is the diagnostics for the code you have.
File Type: pdf
Old Dec 15, 2009 | 03:40 PM
Thank you 69 Bird!!! I will give this a try.
