Random Cylinder Missfire Code
Old Dec 14, 2009 | 10:21 AM
FastB's Avatar
Default Random Cylinder Missfire Code
Everything is stock except for my cam and exhaust. The cam swap was very recent and it has been tuned. Started throwing Random Cylinder Missfire so I find a loose spark plug and wire. Tighten them and code goes away. Drive it for a couple of days no problems and sitting in traffic one night Check engine light comes on again, same code. What could it be this time?
Old Dec 14, 2009 | 10:37 AM
lovingdaddyof2's Avatar
whats the lift and duration of the cam? even with the tune if you idle to long with a decent size cam it will periodically throw that code
Old Dec 14, 2009 | 01:54 PM
FastB's Avatar
226/234 .598”/.602” 111LSA +3 advance
That sounds reasonable I guess, but would the code re-set after the car has been turned off and cranked again?
Old Dec 14, 2009 | 02:01 PM
thats the problem. yes it will reset itself if the problem doesnt happen within a certain amount of time. i have had the same thing for about 3 years now. if it shows a specific cylnder then i would worry. and it looks like your coming pretty close to your piston with that much lift on the exhaust i always heard .600 was about max with out cutting the pistons
Old Dec 14, 2009 | 02:30 PM
FastB's Avatar
Patrick G. spec'd the cam for me so I hope it is ok. I don't think he would have spec'd me a cam based on the info I gave him that would not work. Thanks for the help.
