2010 Camaro TCM Issue
Old Jan 2, 2010 | 12:31 AM
Josh@PremierAutosports's Avatar
Default 2010 Camaro TCM Issue
I have a 2010 Camaro that times out when I try and load in a tune with HP Tuners. It writes the ecu then times out when it goes to write the TCM. Has anyone had this problem and what was the fix?
Old Jan 2, 2010 | 06:43 AM
jay_lt4's Avatar
pull the tcm fuse and let it sit for a couple minutes,, usually only have to do it the first read/write
also get yourself the latest beta and you wont have to disconnect the pcm or pull the batt cable after each read/write and the latest beta also has a 2.5 bar upgrade that lets you keep the maf and have fan control below 195*f
