ls2 stand alone pcm pinouts needed
pick up from the ecu a tacho output (rev counter over here), to go to my tacho
identify what pin 25 on the blue plug is (white wire).
identify 66 on the grey plug (purple/white)
identify 67 on the grey plug '9green/white)
work out if i can use this ecu to output a vss signal to my electronic speedo (have done this with stock gmecu), if so,wha input pins do i need for vss input from trans
can i wire in a mil light to my dash?
can i wire in a low oil light to my dash by taking a wire from the brown ,white oil wire to earth.
i can work most of this out with a pin out, but any help is appreciated
many thanks
