compared tuners
Old Jan 21, 2010 | 06:16 AM
318z28's Avatar
Default compared tuners
would anybody recommend the diablosport predator tuner over the superchips cortex programmer for my 00 z28? not sure what the power differences are between the two but i have the cortex and have heard alot of good things about the predator
Old Jan 21, 2010 | 08:31 PM
06MonteSS's Avatar
LS1Tech Sponsor
the predator has better tunes, more hp/tq gains, data logging, offers more adjustability, plus the ability to get custom tunes created by diablosport CMR custom tuners and store up to 5 of them in the predator....
Info about the U7198 Predator you'd need for your car can be found here:
http://diablosport.com/index.php?mod...display&pid=67
Items you can adjust with it, include:
Timing Table 1000-1800rpm (+/- 20%)
Timing Table 2000-4000rpm (+/- 20%)
Timing Table 4000-7000rpm (+/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (adjustable for Trucks Only - it is already removed in the preset tunes for the cars)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust COT enable temperature
Old Jan 22, 2010 | 08:53 AM
318z28's Avatar
sweet, well looks like my mind is made up, out the window with the superchips!!!
Old Jan 22, 2010 | 11:06 AM
Black02SS's Avatar
Also take a look at EFILive and HPTuners. Don't limit yourself to a handheld device.
Old Jan 22, 2010 | 01:34 PM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Good deal, if you need any assistance with the Predator, look us up or hit up our support forums!
Thanks
Mike
Old Jan 23, 2010 | 02:06 AM
318z28's Avatar
ive got the jet dst (dynamic spectrum tuner) that i used for my previous camaro i had before this one and it was on my computer with windows xp on it and it wont work on my new computer with vista on it so i havent been able to tune it with that either... gotta figure out a way around that
Old Jul 8, 2010 | 01:59 PM
Cannonball1200's Avatar
I've got it on my laptop with Vista. There were some "added" instructions with my new DST. I had to set a couple of perameters to run in "Compatability Mode". I works tho.
Old Sep 16, 2010 | 10:27 AM
jhi45's Avatar
would a diablo still work if I swapped to an LS6? I know the LS1 and LS6 share the same tuner...What would have to be done? Would it recognize the LS6 and tune accordingly?
 Michael S. Palmer
Old Sep 16, 2010 | 10:37 AM
LS1Tech Sponsor
Yeah, we can send you a tune for the LS6 that you can load to the Predator as a custom tune.
Old Sep 17, 2010 | 10:45 AM
jhi45's Avatar
thanks for the reply Mike, I may go ahead and order the tuner pretty soon...might also get one for my truck!
Old Sep 17, 2010 | 11:15 AM
jhi45's Avatar
One more thing Mike. If I got a Diablo for my truck, would I have to go where I got it tuned with EFI Live to get it taken off first before I could use the Diablo? Or will the Diablo override the EFI Live tune?
Old Sep 17, 2010 | 01:31 PM
Frost's Avatar
It could get you into trouble if the EFILive tuner changed up the OS on you...
Old Sep 17, 2010 | 10:57 PM
tallreyes's Avatar
can the diablosport be tuned for a turbo setup? does it come with free tunes for life like the sct does?
Old Sep 20, 2010 | 09:39 PM
upincomin's Avatar
I got my car calibrated today because of a pretty high ticket i got, he said my speedo is off at about 11mph up around 92 or so. The guy said I would have to buy a chip and tuner in order to correct the speedo. Is that accurate? Or does the Predator just plug into the OBD and take care of everything? Thanks in advance.
I'm thinking about buying the Predator at least to show the Judge that "Hey, I know I was wrong, but 1. I didn't think I was going THAT fast, and 2. I'm making the effort to correct the issue."
Old Sep 21, 2010 | 04:39 PM
zo6 vett's Avatar
Default diablo
turbo?
i used the diablo before the turbo with a vararam intake and slp loudmoth.i could not get a twin turbo ls6 done by remote so i had it done with EFI live first,HPTuners next.i bought a CMR (yet to try, middle of motor rebuild)
but i use the diablo to back up and tweak my turbo tune!!
allot easier than a lap top in the car when you can not get 93 oct on a trip or you run out of meth. out of the glove box and presto back done the road.
everyone with a modified tune should have one.the connivance is worth the price of admission.
i did buy hptuners pro and after 2 month sold it.
i have a preditor for every car i can.
mike
Old Sep 21, 2010 | 06:58 PM
jhi45's Avatar
so if your vehicle has efi live on it, you can override it and/or take the efi live tune off and put the diablo tune on? I'm still not clear on the issue...
Old Sep 22, 2010 | 12:37 AM
zo6 vett's Avatar
Default tool is dumb
i took off a efi and hpt tune as a backup.i edited them and installed.the worry about a stock tune is BS.you can have the car reflashed stock at any dealer and start fresh.if your mechanic as the snap on kit(1600.00)he can do it cheaper.i had it a while back.
the diablo is way easier than a lap top in the car.
mike
Old Sep 22, 2010 | 05:23 AM
jhi45's Avatar
you took the efi live and hp tunes off with the diablo? That's the question, the guy that tunes my vehicles with efi live travels everywhere for work and I can only catch him a couple times a month maybe so it's hard to get him to take the tunes off. I would love a diablo for the convenience but love his tunes at the same time, I don't know what to do.
Old Sep 22, 2010 | 11:17 AM
joecar's Avatar
EFILive and HPT are not tunes... they are the editing/flashing tools... they give the tuner the option to lock the tune;
if the tuner locks the tune/PCM then only he can unlock it... the PCM/tune can't be read or written while it is locked.
My understanding is the Diablo is not removing the EFILive/HPT-edited tune, it is adding its edits to the current tune.
Old Sep 23, 2010 | 06:44 PM
zo6 vett's Avatar
Default couldn't have said it better
and, the tuners who lock are not your friend.A buddy had is SC vert tuned by the local "guru" and after having a 6.0 motor done by Texas speed and a shop in bradington Fl finish it up and tune it,i should say try to tune .they found it locked. what a mess new ecu and the lot.
like the man said just tools,time learning is the hard part.
i still think for what it does pretator is best .
i will tune my twin turbo with mine someday
ask 06 mntess about the new release!!!!!!!
said to be the size of a iphone
mike
